Orbi WiFi 7 RBE973
Reply
port forwarding netgear d6400
puttanaro
Tutor
Hello!!! port forwarding of emule work well I have id high!!!but if I test the ports with http://www.yougetsignal.com/tools/open-ports/ the tcp port is open and the udp is closed. While if I test the ports with emule the ports are ok, and if I change the udp port in emule result open also is not opened in the modem!!!my modem is netgear d6400!!!!! The firmware version is V1.0.0.56_1.0.56. Can you help me please????Sorry for my bad english!!!!
Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router|802.11ac Dual Band Gigabit
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: port forwarding netgear d6400
Were you able to get the ports open?
DarrenM
Message 2 of 3
puttanaro
Tutor
I go in activation and forwarding ports!!! Port forwarding of emule work well tcp and udp if test with emule service result open!!tthe strange thing is if I change the udp port in the emule settings result open the same also is not the same of the ruter!!!other strange thing is if I test the udp port of the router with the website http://www.yougetsignal.com/tools/open-ports/ result closed and the port tcp result open!!!!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2043 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
