Reply
update firmware D7000v2 problem
Hopskirk
Hi everyone, I have problems with updating firmware, netgear in the application and on the web interface says it is a new version. unfortunately I can not update, according to the instructions, I want to try manually installing the firmware, but I do not know where to get this firmware. I couldn't find it on netgear with my product. does anyone have any experience with this firmware? thanks for the info:kde stáhnu tuto verzi viz foto.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 6
Hopskirk
Re: update firmware D7000v2 problem
here I am adding a screen shot of genie.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 2 of 6
>>>> D7000v2 | Product | Support | NETGEAR <<<<
The release notes should take you through the update process. Or read the manual.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 6
Hopskirk
looking for this firmware D7000v2 1.0.0.56_1.0.1. this version tells me genie that can be updated. I can't find this version on the Internet, I can't find it. The automatic update freezes.
Message 4 of 6
I know. That's why I answered you.
Please read the response:
Re: update firmware D7000v2 problem - NETGEAR Communities
Just another user.
Message 5 of 6
Hopskirk
problem solved, I found firmware and manually updated from genie interface. thanks to all for your help.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1244 views
  • 0 kudos
  • 2 in conversation
Announcements
