DGEDGEDGE's avatar
DGEDGEDGE
Follower
Nov 30, 2020
GS724Tv4/GS748Tv5 NbMax Vlan in a trunk
I will use one of those swiches to route staticaly port allocated VLANS.
On each port could be assigned a trunk containing around 10 Vlans.
On  Two ports (SFP) could be assigned all VLANS managed by the switch.
Up to 200.
The organisation would be as the following : (Image included as file).
Is there a limitation in those Switches that would forbid such a configuration ?
Note : Compatibility with 1Gb is required on each interface, but total of realtime switching is low.
ProSupport for Business
