Reply
1.0.0.82 --> No Internet. At All.
stevo1569
Hey everyone,
I upgraded to .82 from .66 (which was working well). Immediately after upgrading and doing a 30-30-30 i can connect to the router, pull an IP from the DHCP but I cannot get online. I've tried this process 6+ times and still the same result. I have since reverted to .66 which is working just as well as before.
Anyone having similar issues or have any advice?
Thanks,
Steve.
Message 1 of 12
jmizoguchi
Virtuoso
Re: 1.0.0.82 --> No Internet. At All.
reset the router anytime you flash firmware.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 12
stevo1569
I did that, multiple times........including resetting the comcast modem
Message 3 of 12
jmizoguchi
Virtuoso
did you remove the battery if you have arris cable modem (phone / internet)
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 12
Joe_
Apprentice
stevo1569 wrote:
...I upgraded to .82 from .66 (which was working well).... ...I cannot get online.... I have since reverted to .66 which is working just as well as before...
I know there have been complaints from users about .66, but I recall at least one user saying .66 was working well with his/her router.
What's the lesson to be learned? Upgrading FW just for upgrading sake is foolhardy. If you were having absolutely no problems before, then you are just asking for trouble.
Message 5 of 12
stevo1569
How do i remove the battery?
Message 6 of 12
jmizoguchi
Virtuoso
Works was "IF"! Look side of arris modem IF you are using arris modem with phone service. Most have battery with phone/Internet gateway device
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 12
stevo1569
I do have an Arris modem from Comcast (Business gateway). I found a teardown manual online for it and will give it a try when everyone gets offline for the night and will be back with a status.
Message 8 of 12
spliffstarr
Another thing i noticed after i upgraded was that i could no longer use my old backed up settings from the previous firmwares i Had to set up everything fresh after the upgrade. You could try doing a factory restore and try setting everything up from scratch.
Message 9 of 12
Joe_
Apprentice
spliffstarr wrote:
Another thing i noticed after i upgraded was that i could no longer use my old backed up settings...
See Mars Mug's explanation in post #5 here:
http://forum1.netgear.com/showthread.php?p=373100#post373100
Message 10 of 12
stevo1569
Well that did it. A factory restore accompanied by pulling the battery on my Arris modem fixed it. Putting all the setings back in was a pain in the 4$$ but at least it's working with the .82 firmware.
Only thing that I noticed is now whenever I make any changes to my wireless settings (channel, security, SSID) i wont be able to get internet unless i soft restart both my modem and router.
Anyway, thanks for all the help guys!
Steve.
Message 11 of 12
jmizoguchi
Virtuoso
sounds great... enjoy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 3104 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
