Reply
\\192.168.0.5 not working?
ch3510
Luminary
there is actually a menu to open a media device from the networks pageUntitled2.png
but it just takes me to http://192.168.0.200:1900/Untitled4.png
my flash drive is a fat32 formatted 32gb cruzer blade, any help would be appreciated!
Model: CG3100D-2BPAUS|Cable Gateway Docsis 3.0
Message 1 of 6
Re: \\192.168.0.5 not working?
What is the problem?
What is supposed to be on 192.168.0.5?
By the way, it may not matter, but you have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's impenetrable community structure.) The CG3100D listed in your footer is a Cable Voice Gateway.
You might get better replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 6
schumaku
Guru
What your Windows 10 system does discover and show as Media Devices - Gateway Media Services is indeed the UPnP/DLNA service.
Head to the "Windows-Features" and enable the SMB 1.0/CIFS Client, and reboot. Now retry ...the router should come up under the name configured under ReadyShare btw. as a PC/Server with a blue icon in the Network view of Windows Explorer.
Message 3 of 6
ch3510
Luminary
ignore this :p, i accidentally posted twice
Message 4 of 6
ch3510
Luminary
\\192.168.0.5 is used to access the USB flash drive https://kb.netgear.com/24693/How-to-access-your-USB-device-on-the-N450-CG3000Dv2
And I'll try to post this on the cable modem section
Message 5 of 6
schumaku
Guru
Whats confusing ... the media player of the router is on .200 (like http://192.168.0.200:1900/) - and in the subject you try to reach .5 (like \\192.168.0.5). The ReadyShare (SMB) USB storage service would be on the very same LAN IP, so \\192.168.0.200 for example.
A router is operated on a fixed LAN IP address, typically it's the low .1 (192.168.0.1) - so how comes you find the router LAN IP on various addresses?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3958 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
