Reply
220V power adapter
chucklaurel
Follower
220V power adapter
How do I go about  ordering  the correct power adapters for use in the Philippines (220V/60hz)? I purchased my RBK53 System from Amazon & it came w/ 3 Power Adapters  for 110V only.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: 220V power adapter
netgear doesn't sell after market power adapters.
I haven't tested this but I've read the adapters are 220v compatible though.
https://community.netgear.com/t5/Orbi/ORBI-220V-AC-adapter-works-on-120V/td-p/1814677
If you didn't want to risk it, look at the adapter's output voltage and amperage. Then buy an aftermarket 220v one that has the EXACT same voltage output and at least the same amperage. You'd also want to ensure the polarity was the same.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 619 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
