Reply
3700v1 live parental controls?
farcough
ok so i updated to the
1.0.16.98 and the 1.0.16.98-beta and now my lpc don't work the user interface and the management software don't recognize the router any more???
so i went back to the
1.0.7.98 and it still was playing up work then no work
so i went back to a older firmware
1.0.4.68 and it works now ..
is there anything im missing here as to why the newer firmware dont work???
ty in advance....
or is there a a program i can get that is free to do the same thing ??
will pay if it is the last resort....
Message 1 of 6
mbourd25
Re: 3700v1 live parental controls?
Hi farcough, I have the same issue as what you described. Also, opendns doesn't work anymore since I upgraded to 1.0.16.98 even when I put rules to block sites.
This isn't really good when a company says they use opendns as a service to block malicious sites or to protect your family from other "bad" sites when it doesn't work.
I'll keep an eye on this thread to see what fix is out there.
Message 2 of 6
jmizoguchi
Virtuoso
you need to report this finding with support at my.netgear.com
other third party subscription base will be this..
http://www.bsecure.com/
this used be to part of dlink feature but they have departed.. great services
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 6
Wolf_666
Luminary
I had FW 1.0.16.98NA and everything's working fine. OpenDNS is on and working. Try to install Netgear Genie and use it to setup the parental control.
- Modem Draytek Vigor 160
- Router Netgear RAX200 (Stock FW)
- NAS Synology DS1621+
Message 4 of 6
farcough
ok wolf but can u use the create a group utility ....
like ive got a adults that need more than kids so ive mad up a groups called grownups and they have open internet to do as they please, ive used a netgear program called user utilty to download the router status and i can login as a grownup but anything higher than 1.0.4.68 wont work...
so my question is to you does it work on latest firmware???? with the netgear genie software??
Message 5 of 6
Wolf_666
Luminary
nope, I installed the utility and it does not work with 1.0.16.98.. I did not get your problem since I set IP bypass from router. I use a child-safe dedicated PC. Sorry not to be useful.
Message 6 of 6
Discussion stats
  • 5 replies
  • 2441 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
