Reply
5Ghz Devices?
Berto1
Follower
5Ghz Devices?
Im Trying To Connect My Xbox 360 Slim And Ipod Touch To The 5Ghz Band But Neither Pull It Up Are They Not Compatible? Or Did I Miss Something?
Message 1 of 2
danjr
Re: 5Ghz Devices?
In order to connect to the 5Ghz band on the router, the devices must have a 5Ghz Compatible Network Adapter.
The Xbox 360 is only compatible if it has the black Xbox 360 Wireless N Networking adapter. Otherwise I would suggest connecting to the 2.4Ghz band.
The iPod touch lacks a 5Ghz band WiFi module. Again, you should still be able to connect to the 2.4Ghz band.
Make sure the 2.4Ghz WiFi is set up on your router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3943 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
