Reply
5Ghz to 2.4Ghz auto switch
Smokie365
Tutor
Hi everyone
I was wondering if this is possible?
My routers 5Ghz reception is very bad. The radius ain't great at all.
Is it possible to have my devices connect to the two channels and switch to 2.4 by itself when the signal gets too low from 5ghz?
N speeds are only really achieved when I'm in the same room as the router.
Thanks
Message 1 of 3
sabretooth
Apprentice
Re: 5Ghz to 2.4Ghz auto switch
No I do not think that is possible.
Message 2 of 3
jmizoguchi
Virtuoso
5Ghz has POOR range anyway so if you can use 2.4Ghz, use 2.4Ghz.
Also under roaming , it will still be difficult to change on the fly.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3192 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
