- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
6250 and Chromecast
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks you 'all
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ha, I bet that is it; I have had that Chromecast for close to two years. So it must be a first generation.
Thanks "TheEther", for clarifying this.
Much appreciated!
Wolf
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 6250 and Chromecast
First, do you have a first or second generation Chromecast? The first generation Chromcast does not support 5 GHz.
Second, on Netgear routers, AP isolation really only applies to devices connected to the guest network. If your Chromecast is joined to your regular, non-guest Wi-Fi network, then there is no AP isolation setting. AP isolation is always disabled.
If your Chromecast is joined to the guest network, then there is a setting on the router, called Allow guests to see each other and access my local network that you will want to enable. This will allow the Chromecast to access other Wi-Fi devices joined to the network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Much appreciated!
Wolf
