- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC Adapter for Netgear Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will my AC adapter, which is rated at 10V and 1.2A, work with my Netgear WNDR3800 router, which is rated at 12 V, 2.5A? Is there a general rule of thumb for this, for example: "if both V and A are lower on the AC Adapter that the device, it's okay to use." or something like that? I'm not saying that statement is necessarily true, by the way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC Adapter for Netgear Router
No,
General rule of thumb is to get same V and A replacement adapter as original power adapter.
Look on Amazon or fleabay or other online e-tailors for replacements.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It might run for a bit with lower amperage but it won't be stable.
You can run with a higher amperage power supply but a lower will cause instabilities and issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
if it works your router will be running slower, maybe even wifi disconnects from it being under the necessary voltage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As everyone else says, bad idea.
I chip in only to suggest that you look around for something else in the house that might have the right specifications.
12 V, 2.5A is a pretty widespread specification for electronic kit. For example, I have seen it on powered USB and other PC peripherals.
