Reply
AC800s stuck showing “Shutting Down” Bricked!
AC800S_HELP
Help!
My AC800s is bricked! When I turn it on, it shows the Optus logo and then the screen goes blank and it says "Shutting Down".
Nothing else happens and will stay like that forever until the batter is removed.
The unit does not have a physical reset button so its impossible to use this. Is the unit bricked? Can it be restarted? Help!!!
Message 1 of 2
Re: AC800s stuck showing “Shutting Down” Bricked!
One of these?
AC800S Optus | Product | Support | NETGEAR
If so, it isn't a router.
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Discussion stats
  • 1 reply
  • 491 views
  • 0 kudos
  • 2 in conversation
Announcements
