Reply
ATT u-verse and R6300
Wild72
How can I use my 6300 in combo with the ATT U-verse "gateway"?
Message 1 of 4
jmizoguchi
Virtuoso
Re: ATT u-verse and R6300
u-verse believe not abel to use as bridge mode.
in most cases use router behind the uverse as double nat or use as AP setup
http://kb.netgear.com/app/answers/detail/a_id/965
using AP setup will loose all the firewall features but you can setup correctly with u-verse handle as DHCP and NAT
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
Wild72
Thank you. I'm not sure I understand all the abbreviations, but I am committed to trying. The ATT router isn't half the router that the 6300 is!
Message 3 of 4
Mars Mug
Virtuoso
If the ATT router has a ‘DMZ’ option (and no option for Bridged Mode) then you could use that to put the Netgear router in the DMZ of the ATT, that should avoid most (maybe all) problems of having two routers in series.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 8915 views
  • 0 kudos
  • 3 in conversation
Announcements
