- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Access ReadyShare
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been using this router for a while as a main router with DHCP enabled on it and was hooked up to my modem. Recently i got a new router. Hence i moved this router to one of my rooms and connected an ethernet cable from my main router's LAN port to this router's LAN port. The main router is now running a DHCP server. I have connected 4 different devices to this router and a USB harddriver. I am able to access all of my devices from the main router but i can't access the USB drive. How can i access the the USB driver from my LAN ?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you put the R6100 into wireless access point (AP) mode?
Should be WAN (Internet) port, not LAN port.
You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
General WiFi Routers (Non-Nighthawk) - NETGEAR Communities
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Access ReadyShare
But thanks for the quick reply...
