Reply
Bandwidth Issue
RONB007
Bandwidth Issue
Team,
I need some help troubleshooting a bandwidth issue.  First I my ISP is Comcast -Infinity, the cable modem = Motorola MB8600 (DOCSIS 3.1) ; Router = NETGEAR – AC750 Wireless Duel Band Gigabit Router  - R6050. I have the Blast Internet package which should be 250 MB; only because Comcast could not get the Gigabit service to work. My issue is if I connect my workstation downstairs beside the wan equipment I can consistently get 240 MBs. I have a gigabit switch downstairs and upstairs in my office. I have replaced all my network cables with CAT6 cables and have a 50 ft CAT6 connecting the two switches. If I do a speed test from upstairs either connected to the switch upstairs or directly to the MODEM I average from 70 to 82 MBs. I recall Ethernet has a maximum of 100 ft – is that still correct? I am running the cable from downstairs outside to the attic then between the drywall. You think maybe I need a certain type of CAT6? I believe I have shielded twisted pair. Another issue is when I do a speed test connected to my WIFI; I am only getting about 10 MBs. If I can get the WIFI speeds up I will forego dealing with the wired connections.
Model: R6050|A750 Wireless Dual Band Gigabit Router
Message 1 of 4
antinode
Guru
Re: Bandwidth Issue
> [...] If I do a speed test from upstairs either connected to the
   A 100MHz physical link somewhere could explain that, and a bad cable
could explain a 100MHz physical link.  What do all the port-status LED
indicators (or software reports) indicate?  Gigabit speeds, or less?
> [...] I have replaced all my network cables with CAT6 cables and have
> a 50 ft CAT6 connecting the two switches. [...]
   Did you have a problem with the old cables?  Who assembled and tested
these new cables?
> [...] I recall Ethernet has a maximum of 100 ft - is that still
> correct?
   Not now, not ever.  100 _meters_.
      https://en.wikipedia.org/wiki/Category_5_cable
   If you haul the distant equipment to the neighborhood of the fast
connection, and use known-good (short) cables to connect the
troublesome equipment, is the trouble still present?
> [...] Another issue is when I do a speed test connected to my WIFI; I
   It would be unusual to get better speeds by radio than by wire, if
the wire works properly.
Message 2 of 4
RONB007
Re: Bandwidth Issue
Thanks for the information; I ordered the cable from pc connections. I am ordering a better cable; hopefully. The question about getting a  better radio connection; is this a limitation of the router or is 10 or 11 MB typical for the R6050?
Message 3 of 4
antinode
Guru
Re: Bandwidth Issue
> [...] I am ordering a better cable; hopefully. [...]
   I'd study (or eliminate) the old cables before buying more new cables
which may not help.
> [...] The question about getting a  better radio connection; is this a
   "a  better radio connection" to _what_?  A chain is only as strong as
its weakest link.  If your client device is old and crippled, then the
best router in the world may make no difference.  If the radio channel
is congested, ...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 478 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
