Reply
Blue light on top of router has started flashing
I am using a PC with windows XP. I have use my wndr3400 for over a year. Yesterday the blue light on top, (WPS) started flashing. I have no idea why. Router still working fine. Do I need to upgrade or something? Thanks Wally
Message 1 of 10
Tutor
Re: Blue light on top of router has started flashing
not really upgrade. It will just flash if somebody pushed the button.
Message 2 of 10
Virtuoso
http://www.downloads.netgear.com/files/GDC/WNDR3400V2/WNDR3400v2_UM_03APR2012.pdf
Page22
Wi-Fi Protected Setup (WPS) Method
It will not flash unless someone press the dome button. Also it will go back normal status after 2min.
Read up on manual
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 10
I have another problem as no one is pushing the button. This started yesterday evening and is still blinking. It may stop for awhile but then starts blinking again.
Message 4 of 10
Virtuoso
Possible WPS exploitation
Disable the PIN in the router GUI. Refer to manual
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 10
Thank you, I will give that a try. Wally
Message 6 of 10
I have disabled routers pin and restarted modem and router and light is still flashing.
Message 7 of 10
Virtuoso
Blue light is also wifi broadcast and traffic as well so you will not see flashing 100% stopsSmiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 10
OK, I will leave it as is. I just have never had it flashing b4 and felt something was wrong. Thanks for your assistance, Wally
Message 9 of 10
Virtuoso
in some models pushing the dome button will disable the flashing as well but usually with multiple function on dome button you could have done some..
Anyway. flashing is a good thing... Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 15610 views
  • 0 kudos
  • 3 in conversation
Announcements
