Reply
Highlighted
Follower
Bonded ADSL2+
I'm looking at the Netgear DGND3700 as a replacement for my Cisco DDR2200. It was provided by Centurylink (my ISP) for the 25Mbps DSL service. Their DSL service uses a bonded. Does the DGND3700 support bonded pair?
Message 1 of 5
Highlighted
Re: Bonded ADSL2+
As far as I'm aware from my use of it, the router only supports a single ADSL2+ connection. It does however have a secondary WAN ethernet port for connecting to another router, or directly to something like BT Infinity.
Not sure if that helps or not?
Message 2 of 5
Highlighted
Virtuoso
Re: Bonded ADSL2+
I don't think it does on netgear firmware. you can check DD-WRT if they can do that.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 5
Highlighted
Re: Bonded ADSL2+
Last time I checked, DD-WRT didn't support the DGND3700 router. Has that changed?
Message 4 of 5
Highlighted
Virtuoso
Re: Bonded ADSL2+
I was just saying so have not look at dd-wrt site myself
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3886 views
  • 0 kudos
  • 3 in conversation
Announcements
