Reply
Bridge
slynki
Follower
Bridge
I have a WNDR4500 that I would like to use a Wireless Bridge. Is this possible? Due to the weak security, I cannot use it in Repeater mode.
Thanks for any help.
Message 1 of 5
Retired_Member
Not applicable
Re: Bridge
If you can find it in the manual then yes if not no. I say no because it's not listed in manual, or I missed it.
http://www.downloads.netgear.com/files/GDC/WNDR4500/WNDR4500_UM_25Oct2013.pdf
Message 2 of 5
WizardJ
Luminary
Re: Bridge
That depends. What do you mean by "Wireless Bridge"?
If you are referring to the WDS functionality (Wireless Repeating using WEP/54 Mbit/s), then the only other option is not encrypting the network to allow for higher link rates (450 Mbit/s on your router model).
If you are tech savvy, you could pretty quickly switch out the stock firmware for DD-WRT. That will allow you to hook the router up wirelessly to another router, encrypting the link with WPA. Smiley Happy
8/1 Mbit/s ADSL
Router: D-Link DIR-615
Wired AP: Netgear WNR1000v2
Message 3 of 5
Fairytail
Virtuoso
Re: Bridge
You can only set WNDR4500 to repeater or access point but no option for wireless bridge.
Message 4 of 5
jmizoguchi
Virtuoso
Re: Bridge
Unfortunately no.. Other options are DD-WRT if they offers.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3410 views
  • 0 kudos
  • 5 in conversation
Announcements
