Reply
Bridging WAN+LAN+WIFI
Hi,
I have an existing LAN in my house (192.168.2.x). I want that the clients connecting via Wifi on my R6300 also get IP addresses in the same segment (192.168.2.x).
I finally got it to work but it has been extremely tricky to get setup. I had to set the R6300 WAN to use 192.168.3.x while the inside R6300 LAN and Wifi to 192.168.2.x. And then connect a cable from my main LAN router to one of the LAN ports on the R6300.
However there are two things that do not work anymore:
1) I can't access the R6300 web UI when it is like this. I have to connect a cable from my main router to the WAN port port of the R6300 temporarily.
2) The guest network functionality does not work. Probably because I told it that there should not be any connection between guest and main LAN but the router is only connected by LAN port.
I wish there was a way to easily do this in the R6300. Maybe in a future firmware version?
Thank you
Message 1 of 9
Mentor
Re: Bridging WAN+LAN+WIFI
The golden rule for consumer networks is one network, one router - break it at your own risk.
If you have an existing network you wish to expand wirelessly, the correct device to use is a wireless access point - alternatively - you can replace the router in the existing network with w wireless router - OR - you can add a wireless router configured to function as an access point.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 2 of 9
Virtuoso
You may want to use unit like guest gate. You can easier to control guest
Guest on. R6300 should isolate from the primary LAN so should not worried about it if you use normal setup with cable and r6300
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 9
Good point. I bought the R6300 because it seemed be the best and fastest that Netgear had to offer and wanted to future proof myself. Do you know if it is possible to configure it as an access point? Sounds like exactly what I need.
I am not replacing my main router, it's a Peplink Balance 390 load balancing two internet connections. Smiley Very Happy
Thanks
Message 4 of 9
Virtuoso
you can use AP mode in the router but you also like to loose all the firewall feature.
maybe you should add some vlan and multipe AP instead or use device like guest gate(guestgate.com) and you can plug-n-play to give your clients in no time
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 9
Tutor
Do peplink and guest gate support 5ghtz band
1xR6300 V1 - V1.0.2.36_1.0.28
Message 6 of 9
Not sure, I am not using the Peplink wireless products.
Message 7 of 9
Ok, after some more Googling I found the AP mode of the R6300 hidden away under Advanced > Wireless Settings. There should be a FAQ for this somewhere Smiley Wink
I am now using the AP mode and it does everything I wanted so cheers for that. Any idea what the bridge mode does? Is that to connect two R6300 in a point to point fashion?
Message 8 of 9
Virtuoso
bridge is wireless connecting two which you do not want to use and it is not your setup with your load balancing router you have already.
AP mode the what you want.. Smiley Very Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 6103 views
  • 0 kudos
  • 4 in conversation
Announcements
