- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C3700v2 – N600 not working as router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have my C3700v2 - N600 plugged into a Nighthawk CM1200. The idea is to use the Nighthawk as the modem and the N600 as the router.
Modem is working fine and I have a signla through the modem xfinity connectoin Router is not. Downstream light flashing, upstream light not on, online light not on.
I'm with xfinity. The technician who came by told me the router is in "disabled" (?) mode and he could not reset it.
I can't access the router login as the internet signal itself does not work.
How do I get this working and/or set up as a router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C3700v2 – N600 not working as router
You can't.
The CM1200 isn't a router. Its a modem only device.
And the C3700 doesn't have a router only mode. It can either be a modem/router combo device or a modem only device.
It does have a way to force it into a type of access point but you'd still need a router between the cm1200 and the c3700 if you set that up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I wasn't aware the C3700 doesn't have a router only mode. It's certainly not working as a modem-router combo; the technician I contacted at xfinity claimed this was because it is only DOCSIS 3.0. Would you happen to know why?
I do actually have another router, FIOS-G1100. Can I use this as a primary modem or otherwise "to force it into a type of access point" between the Nighthawk and the C3700?
