Reply
C6300 USB connection
Roxane1
I'm havng an issue establishing a connection between my C6300 and my new WD My Book 4TB External Hard Drive  USB 2.0/3.0 (Model: WDBBGB0040HBK-NESN). PLEASE don't tell me it can't be done.
Message 1 of 4
Guru
Re: C6300 USB connection
What format do you have the drive in?
Certain formats are compatible.
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Also, did you check the compatibility list?
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
its not all inclusive its just the "reported to work" drives.
Is it showing up in the readyshare drive when you log in via the browser?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
Roxane1
Thanks a bunch for youur speedy reply! Smiley Happy
It's format is exFAT but I'm not sue if it's 16 or 32, (probally 32).
It's not on the "proven works" list. Smiley Sad
Message 3 of 4
Guru
It's format is exFAT but I'm not sue if it's 16 or 32, (probally 32).------There's not exFAT16/32. And the exFAT isn't supported. Format it to an appropriate format.
It's not on the "proven works" list. :smileysad:------Just cause its not on the list, doesn't mean it won't work. Format it to a supported format and try it.
Message 4 of 4
Discussion stats
  • 3 replies
  • 412 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
