- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
C6300V2 stopped displaying 5ghz SSID when scanning my networks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C6300V2 stopped displaying 5ghz SSID when scanning my networks
you scroll to the right of the snr.
make sure to include all the download channels. scroll down. your cropping stuff out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now that connection is back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mar 17 2020 09:10:07 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Time Not Established | Critical (3) | No Ranging Response received - T3 time-out |
Mar 16 2020 15:11:58 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 16 2020 07:21:51 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Time Not Established | Warning (5) | ToD request sent - No Response received |
Mar 15 2020 15:49:32 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 15 2020 06:13:44 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 14 2020 02:53:27 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 13 2020 12:46:26 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 13 2020 05:08:46 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 12 2020 09:35:05 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 11 2020 12:37:55 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 11 2020 02:37:54 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 10 2020 17:54:12 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 09 2020 16:10:54 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Mar 09 2020 09:30:07 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
this is all I could find.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's what you can do.
1. factory reset and re-install the combo device.
2. have the isp inspect the line. you're specs don't look bad but it doesn't mean its not something after the hub.
3. try a different modem/router. Potentially it could be the combo device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Plemans, the new Wireless NIC arrived today, all installed, very easily, the one you suggested, works great, although, I had to go into device manage and advanced on the card to get my correct 802.11 settings correct and when I did that, I blew away my network, lololol. Nothing was showing up for available networks, so, I uninstalled the device from device manager, reinstalled the drivers from Intel, recreated my Wireless Network, and now can put my PC on 5GHZ which is showing now. Also, had Comcast Technician come over yesterday, he checked the signal directly into the c6300v2 1750AC, signal strength was strong, so, the dropping of my speed and having to reboot my modem/router every time, to get my speed back, he believes is tied to the Node being house out on the pole somewhere, thinks one of the Link Switches may be having issues, and I asked my neighbor, she has the same problem, so he was putting request in for Watchtower Monitoring to find out, where exactly from Node to panel switches are broken, maybe a fuse on the switch, not sure, so hopefully will know more soon. I wanted to hook up the Bluetooth connection that came with the card, but don't have an additional usb pin plug to put into, my USB ports are hard wired into the circuit board it looks like, but thats okay, I am using a Bluetooth External USB PNP that works just fine. I want to thank you for all the outstanding help you have provided me, many KUDOS to you my new friend!!!! Jeff.
- Mark as New
- Bookmark
- Subscribe
- Permalink
glad to hear you got it working great!
You do want to get the intel drivers directly from intel. windows update doesn't pick up the most recent and its been changing fast with the AX cards.
- « Previous
- 1
- 2
- Next »
