Reply
CGD24N wifi signal cannot always be found
moksha
I have a CGD24N v2 I have 2 laptops that can find it but all my visitors and my android cannot. The Android sometimes finds it then it says out of range this is even when sitting right beside the device. It also has a desktop connected by ethernet that suffers continual disconnection and reconnection problems.
Message 1 of 5
jmizoguchi
Virtuoso
Re: CGD24N wifi signal cannot always be found
check for channel interference issues
http://www.metageek.net/products/inssider-wifi-scanner/?utm_expid=190328-0
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
moksha
It is 6.00 am Sunday morning now so low neighbouring traffic a quick check of what is around shows 5 other networks, spread through channels 1, 6, and 11. I am using channel 13, the Db rating is high.
Message 3 of 5
moksha
I have moved to channel 8 with success currently, I will see how it goes when peak channel loading starts during the week
Message 4 of 5
jmizoguchi
Virtuoso
8 will overlap with 11but if it will work then give it a shot for awhile
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2801 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
