Reply
Call of duty WWII Moderate NAT PC
XanderWentzel
Follower
hey I have some problems with my cod ww2 I can't set my lan to open plz help
here is a pic if et helps
https://gyazo.com/169a0356b222a77723cac4bb7704ee72
Model: WNR2000v5|N300 WiFi Router
Message 1 of 3
TheEther
Guru
Re: Call of duty WWII Moderate NAT PC
Did you follow the advice given in the picture? Either enable UPnP on your router or set up port forwarding for port 3074.
And make sure you don't have double NAT (i.e. two routers back to back).
Message 2 of 3
roman4525
I have been having the same issues and ive done everything possible as well port forwarding and setting my PC to a static IP, ive also deactivated then reactivated uPnP. Yet my nat is still coming up as moderate.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1781 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
