Reply
Can't upgrade firmware! DGND3700v2
guidocioni
Hi all,
i'm having serious issues with my brand new DGND3700v2. I've the v1 of this router in another house and it's been working flawlessy for years, this new version instead is giving me some problems..
WiFi stop working after many days, adsl connection drop after uploading & downloading files..i'm not very happy considered that i've payed 169€ for this.
Anyway, i've spoken with Netgear Assistance on the phone and, after various attempts to fix problems, they suggest me to try the beta firmware V1.1.00.12_1.00.12_t4 . Wrong. This firmware is so bugged...i've done all the necessary reset and followed all the instructions and now i can't
    When i'm trying to update firmware i select the newest firmware in the choose box but then pressing on "upload" button doesn't work at all. And yes i've tried with Internet Explorer, Mozilla, Chrome, Safari and i've hard resetted the router at least twice... So...now?
Message 1 of 16
jmizoguchi
Virtuoso
Re: Can't upgrade firmware! DGND3700v2
reset the router first and try again
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 16
guidocioni
I've reset my router like 5 times...
Message 3 of 16
jmizoguchi
Virtuoso
Did you lost all your setting to your route? if so you did hard reset correct.. Power on/off is not reset
Also use ethernet cable to the router. You can not use wireless to upgrade firmware
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 16
guidocioni
Man, don't take it personally but i'm not stupid 😄
I've reset the router 5 TIMES, not just turned it off, like the guy from tecnichal support said (turned it off, unplugged all the cable, turned it on, waited, press reset button for 20 sec, wait for turned on). And yes i'm updating using ethernet.
This firmware is not good, i'm just reporting because i know what i'm doing. But now i'd like to know a way to change because i can't move from there..maybe i've to force upgrade on telnet..
Message 5 of 16
guidocioni
Message 6 of 16
jmizoguchi
Virtuoso
use TFTP method try upload the firmware
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 16
guidocioni
Any guide? links?
Not able to find anything in google that's reliable
Message 8 of 16
jmizoguchi
Virtuoso
http://forum1.netgear.com/showthread.php?t=30453
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 9 of 16
huhugrub
Message 10 of 16
mello29
I tried to do that procedure several times, but it didn't worked.
What's the next step?
Message 11 of 16
jmizoguchi
Virtuoso
Brick unit. New router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 12 of 16
sabretooth
Apprentice
You router is toast. Need to buy a new one if you can not unbrick it.
Message 13 of 16
mello29
Thanks, on Monday I'll call the costumer care.
Message 14 of 16
NUTTER123
Seems to be a 1.1.00.15 version out now:
http://support.netgear.com/product/DGND3700V2
Message 15 of 16
mello29
Netgear support helped me and now the problem is solved! 😄
It's very easy: I'm italian, so I set the italian language on the router, but beta firmwares work only in "English". I reset language to english and everything works. 🙂
Message 16 of 16
Discussion stats
  • 15 replies
  • 8469 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
