Reply
Cannot Connect EX3700 to Router After EX3700 Firmware Update
After upgrading the EX3700 firmware to the latest version, I could not connect to my Synology router to the extender. All of the setup steps worked properly until the actual connection step. I have tried several times, reset the extender to factory default, and connected via ethernet cable with the wireless shut off. The unit is out of warranty so Netgear is not willing to talk to me. Any assistance would be appreciated.
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 7
Guru
Re: Cannot Connect EX3700 to Router After EX3700 Firmware Update
a bit more info is needed.
I'm unsure by what you typed if you've shut off wireless on the router, the extender, or the laptop.
What did you wire into the extender? A laptop?
Where in the process is it failing?
Are you setting it up using wps or using the installation assistant?
What firmware is on the extender?
CM2000-> Arris AX11000 W31-> GS716v2-> WAX***-AP
Message 2 of 7
@plemans
Thanks for the quick response and offer to help. Information is embedded.
[AB] I shut off the wireless service on the laptop to ensure I used the ethernet connection to the EX3700.
[AB] The ethernet cable is between the laptop and the extender.
[AB] The step that fails is connecting the extender to the router after selecting the SSIDs of the router, the password, and giving the extender unique SSIDs. I can send a screen shot if that would help, though it will take a few days as I do not have access to the extender or my home network right now.
[AB] I am using the installation assistant and the manual option, not wps.
[AB] The firmware I saw on the extender was V1.0.0.84_1.0.56. If resetting to factory defaults does not reset the firmware, this is the version on which I saw the failure. If it does restore the as-shipped firmware, I don't know the version, but am experiencing the problem on a version that previously worked.
Message 3 of 7
Guru
Did it ever work?
Have you checked with synology at all? some of their devices use a mesh function and maybe it needs to be disabled with extenders
Message 4 of 7
@plemans
Thank you. I will check with Synology. I started with Netgear because the failure began immediately after the firmware update. There is a chance that their last update introduced a problem that was not visible until I tried to reconnect the extender. I'll see if I can capture the packets as it attempts to connect.
Message 5 of 7
@plemans- Thanks for the suggestion. I got in touch with Synology. They are not aware of other reports of this issue. Please note that it started immediately after a Netgear firmware update.
Is there any way for me to drop back one version of firmware to see if the problem goes away?
Message 6 of 7
Guru
yes you can downgrade the firmware. You download it from the support site and then follow the "manual firmware update" process from the manual. and instead of using new firmware, you use the old firmware.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 363 views
  • 0 kudos
  • 2 in conversation
Announcements
