× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Cannot access router management
uptownvideo
Apprentice
I have not been able to access the router management page using a computer or mobile app since lately.  I have tried chrome, safarit, firefox and the Genie app.  I even tried my laptop hard wired ethernet.  This is a cable modem/router combination.  I did try to power cycle it last night but I got the same results when it came back online.  It works fine for internet, but I do like to have access to the router managemnet occasionaly.
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 9
Guru
Re: Cannot access router management
You have the C6300?
did you try using its ip address? or using the routerlogin address?
Try 192.168.1.1
or
192.168.100.1
Message 2 of 9
uptownvideo
Apprentice
Yes the model is C6300.  I tried that router IP and routerlogin.net in different web browsers.  It has always has been 192.168.0.1.
Message 3 of 9
Guru
did you try the modem side? 192.168.100.1
Message 4 of 9
uptownvideo
Apprentice
yes I tried that also.
"Safari Can't Connect to the Server"
Message 5 of 9
Guru
Have you tried a factory reset?
Push and hold reset for 7-15 seconds while powered on?
Message 6 of 9
uptownvideo
Apprentice
I have not done a factory reset as that is probably too drastic to do now.  Will that erase all configs such as SSIDs and passwords?
Message 7 of 9
Guru
Yes. but you can put in the same ssid/password when you reinstall and devices should auto-reconnect
Message 8 of 9
uptownvideo
Apprentice
I may try that tonight.  Thanks.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1352 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
