Reply
Cannot connect after scheduled shutdown
kdowker
Follower
I am routinely having issues connecting to my wifi router after it's scheduled shutdown period. My router (R6250) is dual-band.
Network 1: 2.4GHz b/g/n - scheduled for auto turn off
Network 2: 5GHz a/n/ac - no schedule
Network 1 is scheduled to turn off between the ours of 11pm and 6am. Every morning I cannot connect to this network. When I try to connect using my iPhone, I get an "Incorrect password" error. Using my computer, it just says it cannot connect. I have to regularly reboot the router in order to reestablish a connection to this network.
I'm hoping there's a simple answer to this issue; otherwise, I'll be purchasing another router.
Message 1 of 2
DexterJB
NETGEAR Moderator
Re: Cannot connect after scheduled shutdown
Hi @kdowker,
If the router is already using the latest firmware, I recommend performing a firmware re-flash then reset and reconfigure the router. You may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2648 views
  • 0 kudos
  • 2 in conversation
Announcements
