Reply
Highlighted
Follower
Cannot log into RBR50 because of ad for Circle
I cannot log into my Orbi router because it shows an ad for something called Circle instead of the login prompt.  If I close the ad, I just get a 400 error.  I cannot configure my router or install a firmware upgrade either, because I cannot log in.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Highlighted
Re: Cannot log into RBR50 because of ad for Circle
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 57 views
  • 0 kudos
  • 2 in conversation
Announcements
