Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot reconnect ex2700 to wireless network
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-09-25
05:47 PM
2021-09-25
05:47 PM
Ex2700 has worked successfully in the past. Do to a router failure, cable company installed a new router. A colix gigaspire. I have tried multiple times to setup the extender after a factory reset. The end result is always the same, after going through the setup, reaching the stage where other WiFi devices are connected to the newly created extender WiFii ssid. At that point a www.mywifiext.com page requesting a username and password.l comes up. I can’t get past this screen using the default username and password.
This has occurred when setting up over a WiFi connection or using an Ethernet hardwire.
Any advice is appreciated. Is this extender toast?
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-09-26
06:43 AM
2021-09-26
06:43 AM
Re: Cannot reconnect ex2700 to wireless network
When you're setting it up, are you using WPS?
What actual router model is it?
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-09-26
08:51 AM
2021-09-26
08:51 AM
Gigaspire gs4220e
I have tried WPS, no success
Used GUI over WiFi no success
On my laptop and on my iPhone
Used GUI over Ethernet cable between ex2700 and lapptop
Thanks
Thanks
Message 3 of 3
Announcements
