Reply
Cannot set up wireless with WGR614 v6
jimmymac51
Hello -
Have a new laptop that I got a few months back - have not been able to set up wireless network with our old WGR614 v6 router.
Background
Dell inspiron / Windows 7 Pro HE
Wireless network is available, but connection fails. I hv re-set up three times / have also added mac address for new wireless card. I think the router just is not recognizing the pc, but I can't seem to fix.
Note - have a nook as well and it doesn't even see the wireless network - not sure if that is related or pertinent.
Thanks in advance - Jim
Message 1 of 11
jmizoguchi
Virtuoso
Re: Cannot set up wireless with WGR614 v6
I would not use wireless access list.
make sure to use WPA, WPA2 encryption but try with NO encryption and if works or not
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 11
jimmymac51
Thanks for your quick response June. I disabled WPA and attempted to connect, but rcv same message. Unable to connect...
I appreciate your continued assistance - Thanks - Jim
Message 3 of 11
jmizoguchi
Virtuoso
Hard to say but some of the newer n adapter on PC side is not compatible with older routers
Trying using different wireless mode- g only instead of B&G only
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 11
Mars Mug
Virtuoso
Did you disable the Wireless Access List as June suggested, this is often a problem?
Also, did you change the default network name (SSID) to be sure that you are attempting to connect to your network.
Message 5 of 11
jimmymac51
June / Andy -
I tried each idea - using wireless mode G only and turning off the access list. Also, I have renamed default SSID 3x over course of last several days trying to re-set everything. Still no access.
I appreciate the ideas. I hv heard some people mention problems with W7 and the older routers... maybe time for new router?
Jim
Message 6 of 11
jmizoguchi
Virtuoso
Probably not a bad idea,,,,,Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 11
Mars Mug
Virtuoso
You should not really need a new router for this issue, but it’s often the kind if reason I use for buying new.
Message 8 of 11
jimmymac51
I guess that's the value proposition right? Do I keep tweaking settings and perhaps get it going in a day or three or five...or do I go spend $50 and have it up and running in an hour. (or do I sit in a chair wired / chained to modem? lol).
I do appreciate your guys taking the time to give me some ideas. One more thing - does it matter that the wireless network was orignally set up with another laptop?
Thks
Message 9 of 11
jmizoguchi
Virtuoso
Router does not matter how it was setup Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 11
jimmymac51
Thanks guys. Picked up an N300 and 15 minutes later the house is wireless again. It's good to be free - LOL.
Thanks again for trying - Jim
Message 11 of 11
Discussion stats
  • 10 replies
  • 4553 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
