× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Cant connect to C6300
marjay502
Follower
I have the c6300 and Im trying to get into it to use the dual frequecy mode becuase my video door came doesnt connect to 5mhz but 2.4    How can i get into the modem to change that.   Ive tried routerlogin.com and .net and the IP address and the site doesnt work.
Do I need to do a full reset to get in a config that setting
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 2
Guru
Re: Cant connect to C6300
what error are you getting?
Have you tried a different browser/pc?
If you pull up a command prompt on a windows pc, type "ipconfig"  the default gateway should be the ip address.
You can also try 192.168.100.1
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 549 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
