× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Change IP on Router. Default Gateway address dissappears
racingsubby
Follower
I'm wanting to setup this router and a 2nd network on my home system. I am wanting to having this router in my shop so I ran the cable from the house to the shop and now need to set this up.  From my understanding all I need to do is:
1.  Change the Router ID (a.k.a. what it shows for Default Gateway when I do and ipconfing).
2. Disable DHCP Server
3. Change Router name if I want to have it as a seperate network.
I'm having problems with the first step.  After I change the Default Gateway, it doesn't populate that line when I do an ipconfig and I cannot communicate with the router by typing in the new address.  I've tried everything.  I've reset the adapater, I've flushed the network shell, I've rebooted, dosey-doed.....etc.
Any help is appreciated here!
Model: R6260|AC1600 Smart WiFi Router Dual Band Gigabit
Message 1 of 3
Guru
Re: Change IP on Router. Default Gateway address dissappears
Have you tried just putting it in AP mode? (access point)
That achieves the functions you're trying.
https://kb.netgear.com/23784/I-m-setting-up-my-NETGEAR-router-for-the-first-time-how-do-I-set-it-to-...
Message 2 of 3
antinode
Guru
   Why?  What, exactly, does "a 2nd network" mean to you?  Is there some
actual problem which you are trying to solve?  Care to share?
> [...] From my understanding [...]
   Doesn't sound very good to me.  But my understanding of your actual
goal is negligible.
   Not a useful description of anything.  Inventing your own, private
technical terms ("the Router ID") is not conducive to good
communication.  Stick with the language in the User Manual and on the
management web site.
> [...] dosey-doed.....etc.
   Think, for a moment, about how little useful information those
(non-)descriptions convey to the non-psychics in your audience.
   Perhaps his psychic powers exceed mine.  I don't know what you
actually want.
Message 3 of 3
Discussion stats
  • 2 replies
  • 562 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
