Reply
Changed IP and now no access
bIGmIKE0596
I installed the WNDR3700v2 behind the Verizon router and gave it an IP address 192.168.1.2. Turned off DHCP and configured wireless. Installed on network and all wireless devices access the Internet OK. I am now trying to access the admin panel and www.routerlogin.com brings up Netgear site. I tired 192.168.1.2, directly connected to the Netgear and nothing comes up. Tried 192.168.0.1 - no luck. I went to the Verizon router and the Netgear shows up at 192.168.1.2.
Message 1 of 8
bIGmIKE0596
Re: Changed IP and now no access
I meant to say www.routerlogin.net
Message 2 of 8
bIGmIKE0596
Additional strange information. I ping /a 192.168.1.2 from my desktop and it responds back with Pinging www.routerlogin.net [192.168.1.2] When I use a netbook directly connected to the router it responds Pinging Netgear_DGND3700v2.home [192.168.1.2] Why the different names? When I try to login with www.routerlogin.net from the desktop it times out. When I do that from the netbook it gives me the Netgear website.
Message 3 of 8
jmizoguchi
Virtuoso
http://kb.netgear.com/app/answers/detail/a_id/965
this is how it should be setup and should be working
now sure why you would get that... rest the unit and try all again
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 4 of 8
bIGmIKE0596
That is how I have it installed except I used 192.168.1.2 for the Netgear. 99 is already used by a printer.
Message 5 of 8
jmizoguchi
Virtuoso
as long it is outside of DHCP (recommended ) then all should work
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 8
fordem
Mentor
The www.routerlogin.net URL will only resolve to the router if the router is being used as a DNS proxy - in you network it's not.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 7 of 8
Scubbie
Apprentice
It is also sometimes necessary to actually type "routerlogin.net" without the "www".
Also if you are genuinely concerned about an IP Address which has been manually set, like on the printer, try navigating to the LAN IP setup page and set up the 'Address Reservation' feature. This will prevent any other device from using that IP Address.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3017 views
  • 0 kudos
  • 4 in conversation
Announcements
