Reply
Changing channels on WNR2000v2 using a mac
Please_help
Follower
How does one change channels on WNR2000v2 (wireless router). I'm trying to add a second appleTV to my network... but, it won't connect. Apple said I should try a different channel on my router. (i can't seem to find any control panel or icon or anything at all in finder regarding my router).
Message 1 of 3
jmizoguchi
Virtuoso
Re: Changing channels on WNR2000v2 using a mac
read manual
support.netgear.com and download manual.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
Mars Mug
Virtuoso
I know very little about MACs, but the router operation is the same with a MAC or a PC, i.e. it’s a stand alone network device that is not controlled by any specific computer, no ‘drivers’ are needed, so there may well be no control panel icons.
If the MAC is connected to the router and able to access the Internet, then it is operating on the correct LAN subnet. If you are able to find the IP address allocated to the MAC e.g. 192.168.1.x, then the router IP address will by default be 192.168.1.1 and can be accessed there via an internet browser at http://192.168.1.1
It is possible that the router can change the LAN subnet from the default to 10.0.0.x typically. This can occur if the router is allocated a 192.168.x.y IP address on its WAN side from the modem. Many DSL models are also routers and are the most common cause of the router automatic LAN IP range change, but some cable modems also have routing functions e.g. those that provide VoIP functions.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2923 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
