Reply
Compatibility
Rosalia
Compatibility
Is this modem compatible
Message 1 of 5
Guru
Re: Compatibility
which modem?
Compatible with what?
You gave us nothing to go off
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 5
Rosalia
Re: Compatibility
So sorry. Model CM600
Rosalie Parody
Message 3 of 5
Rosalia
Re: Compatibility
Comparable with xfinity and roku
Sorry I’m old and trying to understand what goes with what.
Rosalie Parody
Message 4 of 5
Guru
Re: Compatibility
1. The cm600 is compatible with xfinity.
2. The cm600 is a modem only. it doesn't have routing features/wireless/etc. So if you connected it to a roku, that'd be the only device you could connect it to. Most go modem----->router------>devices.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 404 views
  • 0 kudos
  • 2 in conversation
Announcements
