Reply
Conect to "Smart" TV
DHR0x
I can't get my Vizio Smart TV to conect to the N900 router.   It (TV) sees the router Netgear43 but doesn't respond to the password.  What do I do?  Thanks
Model: WNDR4500v2|N900 Wireless Dual Band Gigabit Router
Message 1 of 6
Guru
Re: Conect to "Smart" TV
Which model # tv?
What firmware is on the router?
Are any other devices having issues?
How far from the tv is the router?
What error are you getting from the tv?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 6
DHR0x
Firmwear?  Router is out of the box. no additions that I am aware of .
TV about 60-65 ft from Router
PC gets the Netflix
Message 3 of 6
PC gets the Netflix
The WNDR4500v2 is now pretty ancient. (First unleashed in 2013.) So there will probably be several firmware updates since then.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
Feed in the model number from the label on the device.
If you are using wifi to connect the TV to a router, that is a hell of stretch, especially for a device with ancient wifi technology.
If the TV has a wired Ethernet connection, look into Powerline Ethernet. Easier to set up and less prone to interference.
In either case, it is down to the TV to play ball. The router just provides Internet. The TV has to negotiate the connection to the wifi.
You never did answer the question from @plemans
"What error are you getting from the tv?"
It is important.
@DHR0x wrote:
PC gets the Netflix
Where does the PC enter into the picture.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 6
Guru
@DHR0x wrote:
Firmwear?  Router is out of the box. no additions that I am aware of .----Firmware is the coding the runs the router. Did you update it? log into the router and its status page should have firmware version. Please list it here so we know what version you're on.
PC gets the Netflix----are other devices having issues connecting to the router via wireless?
Which model # tv?
Are you trying to connect via 2.4ghz or 5ghz?
Some tv's have issues with special characters in the passwords. If your password has these, i'd recommend changing it.
What modem are you using?
Message 5 of 6
DHR0x
Thanks for the help! I'm going to install the Power booster this morning.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 499 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
