Reply
Connect Netgear Wireless Router R6200 to Comcast Wireless Gateway Arris TG862
Konstin
Follower
How do I Connect Netgear Wireless Router R6300 to Comcast Wireless Gateway Arris TG862?
Message 1 of 2
TheEther
Guru
Re: Connect Netgear Wireless Router R6200 to Comcast Wireless Gateway Arris TG862
Plug yellow R6200 Internet Port into TG862 Ethernet Port.
If you want to continue using the TG862 as the main router, then enable AP Mode on the R6200.  Setting is in ADVANCED > Wireless AP > Enable AP Mode. Configure the R6200 Wi-Fi networks before you enable AP Mode.
If you want the R6200 to take over as the main router, then you'll need to enable bridge mode on the TG862. This thread on TWC's forum shows instructions to enable it yourself, but it may not work with your Comcast service. You may have to call Comcast and ask them to enable it for you.
Good luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3469 views
  • 0 kudos
  • 2 in conversation
Announcements
