Reply
Connect WNR834B to wireless hotspot
carLito
Novice
I have a Rangemax WNR834B dd-wrt v24 that I would like to use as a repeater to boost the signal from a WiFi Hotspot where I live. When I log into the hotspot, it does ask for a code. I have tried the walk-thrus and tutorials on this but can't seem to get it working.
I have two netbooks running windows 7 and a wireless printer that will connect to my router. I have tried various methods to get it working, but my router does not recieve an IP address from the router. Any help will be greatly appreciated.
Message 1 of 6
jmizoguchi
Virtuoso
Re: Connect WNR834B to wireless hotspot
if uses code then will not work with router to connect.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 6
carLito
Novice
I set up a re1000 range extender for a neighbor, same wifi hotspot. All he has to do is open the browser and it prompts him to enter the code and it works fine, isn't that the same thing as what I'm trying to do? The hotspot will allow you to connect to the router, but no internet access until you enter the code.
Message 3 of 6
jmizoguchi
Virtuoso
extender and repeat is different thing so not sure how DD-WRT can do it but different in setups
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 6
carLito
Novice
Sounds like basically the same thing to me, what's the difference between an extender and a repeater?
Message 5 of 6
jmizoguchi
Virtuoso
extender JOIN the existing network
repeat uses are repeating signal which trust the mac address and must configure on both sides to connect
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3090 views
  • 0 kudos
  • 2 in conversation
Announcements
