Reply
Highlighted
Novice
Novice
Connect request fails, can't see router
I'm trying to fix the router after yet another firmware corruption. I know what to do but when I try to put the file to the router I get a "Timeout error, request connect failed.: I can't see the router on IPCONFIG. I've reset the router, tried different lan ports and cords, done everything I know to do. The power light just keeps blinking green. Any ideas? Any help would be appreciated. Thanks!!
Message 1 of 4
Highlighted
Virtuoso
Re: Connect request fails, can't see router
If router is no longer reachable via Ping then router is no longer communicating. TFTP will not work with this.
Message 2 of 4
Highlighted
Novice
Novice
Is this fixable or is the router done for? Is there a way around it?
Message 3 of 4
Highlighted
Virtuoso
Try setting a static IP on your computer in range with the router.
Ex.
IP: 192.168.1.2
SM: 255.255.225.0
DG: 192.168.1.1
If you are done setting a static IP then try pinging the router. It gives valid replies then proceed to TFTP:
Reinstall the firmware on a router without the setup CD recovery tool:
http://kb.netgear.com/app/answers/detail/a_id/19841/related/1
If it is still unreachable then it's dead.
Message 4 of 4
Discussion stats
  • 3 replies
  • 13004 views
  • 0 kudos
  • 2 in conversation
Announcements
