Reply
Connections by SSID
tachyon_pulse
Connections by SSID
I know that from the "Active Connections" screen you can see all the wired and wireless connections, but is there a way to see the SSID being used by each of the wireless connections?
Message 1 of 5
Scubbie
Apprentice
Re: Connections by SSID
I have just taken another look at the list of attached devices in both the 'Basic' and 'Advanced' screens. Both only differentiate between Wired and Wireless connections.
So other than accessing the device in question to see which SSID it is using, there is no other method.
Sorry.
Message 2 of 5
tachyon_pulse
That is unfortunate, but an opportunity for an enhancement. Since the basic "Attached Devices" screen has the notice "Wireless Devices (Wireless intruders also show up here)" it would be good to know which SSID has been compromised.
Is there a way to restrict each SSID to a specific address range via DHCP?
Message 3 of 5
sabretooth
Apprentice
Just use WPA2-AES encryption with a strong password that only you give out and now you know who is on your network.
Message 4 of 5
jmizoguchi
Virtuoso
you will not able to restrict the SSID with DHCP.
you will need more devices to do some like that.
Netgear home end router will not configure to such setup on single boxes.
far as SSID list, that maybe something you scan request support as enhancement to see the better logging
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2418 views
  • 0 kudos
  • 4 in conversation
Announcements
