Reply
Create LAN using AC2300 without internet
jamesr72
Follower
Yes I'm waiting for my cable router to be delivered for internet but in the meantime I would like to use my router as a LAN so I can stream to my TV. When I plug it in the only light on the front is the power light. How do I get it to broadcast a signal?
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
antinode
Guru
Re: Create LAN using AC2300 without internet
> Create LAN using AC2300 [...]
   "AC2300" is a speed, not a model number.  Look at the product label.
   Not a router.  About what, exactly, are we talking?
> [...] When I plug it in the only light on the front is the power
> light. [...]
   Does your (mystery) router work with a wired client device?
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Look for the LED
descriptions and "Troubleshoot".  Pay special attention to "WiFi On/Off
button".  (Did you press it?)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 247 views
  • 0 kudos
  • 2 in conversation
Announcements
