Reply
Cumputer unable to Connect to Network of WNDR3700
Fab4
Follower
Have an HP dv8 notebook that was connected to WNDR3700 wirelessly for two years. Than started to disconnect, increasingly closer in timelines, until it now the wireless card on computer sees available newtorks and signal strengths; however, is completely unable to connect when one tries.
I have two other computers, xbox, and DVR box that all connect to this wireless router and stream without issues. This computer developed a glitch. I also wiped the computer clean and reinstalled factory software. Still get the same response.
HP Tech support says it is a router connectivity issue, not a wireless card issue, and Neatgear should be able to provide assistance. Help?
Fab4
Message 1 of 3
jmizoguchi
Virtuoso
Re: Cumputer unable to Connect to Network of WNDR3700
since you wipe, make sure wifi driver/app is updated from the chipset company and all the windows updates are updated .
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
sabretooth
Apprentice
Along with the above info from June, remove all security from the router and try to connect temporarily with no security. Are you able to?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5094 views
  • 0 kudos
  • 3 in conversation
Announcements
