Reply
D6300 wireless repeater disconnects under load
TGLusch
Luminary
Hello,
I have two D6300 DSL routers in a repeater configuration with a wired QNAP drive connected to the repeater. When I backup my laptop which is connected to the primary D6300 and across to the QNAP via the repeater D6300 it fails after a couple of minutes as the repeater has disconnected. Day to Day use of the repeater is fine as I have an Apple TV connected to it and it accepts HD video loads. It seems to be very large backup files that cause the problem. Any ideas why this is happening and how to solve?
I have checked wireless channel conflicts but luckily nothing there.
Thanks
Message 1 of 4
jmizoguchi
Virtuoso
Re: D6300 wireless repeater disconnects under load
Repeat is half performance so probably bad idea to do it
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
czecht
Luminary
"netgear WNDR3400v2" connect to "qnap TS-569"
I don't know where to ask my question.
I have Qnap TS-569-Pro connected to WNDR3400v2 and I can't seem to be able to see the Qnap server at all.
Does anyone knows how to do this?
Thanks guys!
Tony
Message 3 of 4
jmizoguchi
Virtuoso
Re: "netgear WNDR3400v2" connect to "qnap TS-569"
Thanks guys!
Tony
You post needs to be here
http://forum1.netgear.com/forumdisplay.php?f=33
Root of aboe URL
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3945 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
