× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
D6400 firmware upgrades fails
CliveB
Follower
Have tried upgrading to D6400-V1.0.0.88_1.0.88.chk via the router and via my mac from a dowloaded file. It seems to download but the little blue picture keeps on turning and it never finishes. Works OK when I exit the router but its still on V1.0.0.86
Why does it not go through. Have tried several times
Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router?802.11ac Dual Band Gigabit
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: D6400 firmware upgrades fails
> [...] via the router and via my mac from a dowloaded file. [...]
   That tells me nothing.  What, exactly, did you do?
> [...] D6400-V1.0.0.88_1.0.88.chk [...]
   Presumably, if you got that file, then you also got the Release Notes
file, which points to the D6400 User Manual.  Look for "Manually Upload
New Firmware and Update the Modem Router"?
Message 2 of 2
All Replies
antinode
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1862 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
