Reply
DG834 problem
cod7gba
DG834 problem
Hi
I've had a DG834 wireless modem/router for a couple of years and had no problems with it, used it with Ipods, Various Laptops, phones etc etc.
Recently I bought a Toshiba windows 7 laptop and connected to my wifi and within about 10 minutes it just kills the wifi on the Router. No other devices can connect via wifi - in fact you can't even see the SSID on the network, although it still continues to work wired.
The only fix is a repower of the device and disabling the wifi on the laptop. Both the DG834 and the Tosh are both upto date with patches and firmware etc. I've also tried two Laptops (my first had to go back due to a battery problem) and they both do the same thing!
Message 1 of 7
jmizoguchi
Virtuoso
Re: DG834 problem
possible bad power supply causing the wifi to fail or internal wireless is going bad.
try replacing power supply if you have spare to test with but otherwise unless you got other major channel interference with surrounding wireless, you may have bad unit
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 7
cod7gba
Re: DG834 problem
Thanks, think I'm going to swap the netgear for something else, shame because its been v.good up to now...
Message 3 of 7
jmizoguchi
Virtuoso
Re: DG834 problem
stuff is never last forever... lol
It will be help devices if you use APC Backup UPS or similar ...Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 7
cod7gba
Re: DG834 problem
Very odd, it will work fine for months with any other device but within 10 mins of using the brand new toshiba, wifi stops working. Perhaps it's the laptop at fault?
Message 5 of 7
jmizoguchi
Virtuoso
Re: DG834 problem
sometime working with old 802.11g can be an issues with new 802.11N wifi adapter which are backward compatible with 802.11g router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 7
cod7gba
Re: DG834 problem
... thanks - think you're right, time for a new Wireless Router I think Smiley Sad
Message 7 of 7
Discussion stats
  • 6 replies
  • 4765 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
