Reply
DG8348G wifi signal on but PC can't connect
calibre
Follower
Hi, this router's wifi has been fine for the past three years and all of a sudden my Win7 laptop refuses to connect to it.
Signal strength is excellent. Tried disabling all security/password and still Win7 says 'Windows was unable to connect to this network'. Wired connections work fine.
Any ideas? I don't want to hard reset the router unless I have to as I'll lose a lot of settings.
Message 1 of 2
Mars Mug
Virtuoso
Re: DG8348G wifi signal on but PC can't connect
Have you tried using a different wireless device to connect to the router? You could save the current configuration to a file if you want to try a factory reset.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2114 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
