Reply
DG834G port forwarding query/issue
Roxy1
Apprentice
Hello.
I have a V4 834G with 5.01.14.
I am 100% confident with port forwarding and exactly how to do it with this router. Unfortunately it seems that no matter the inbound rules put in place, all port testing shows the ports closed.
Furthermore, programs like Bittorrent indicate the ports are open, however if I remove the firewall rules from the router, Bittorrent shows the ports closed yet the stream of data is unaffected or compromised. I.e. I do not lose speed or stability of the torrent.
I find this strange that all ports are listed as closed but games and Bittorrent work fine.
I have heard this may be firmware related but would like to avoid a reflash to an older version if possible.
Message 1 of 2
jmizoguchi
Virtuoso
Re: DG834G port forwarding query/issue
if there uPnP feature in router gui, disable it .
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2569 views
  • 0 kudos
  • 2 in conversation
Announcements
