Reply
DG834N modem only and WNDR4500
bwff
Hey all, I need some help here, I have a faithful DG834Nv1 adsl router which is now sadly giving me issues with it's wireless network. This issues requires me to power off and on the router to get it working, the DG834N has started to get poor throughput on wireless also, so I do not think my DG834Nv1 has much life left in this world.
Now I plan to move to infinity within a month so I am not wanting to buy an adsl router, so I would like to get an Netgear WNDR4500 setup and also ensure that I have a wireless network that is functioning.
Now my plan is to put the DG834N into modem mode and use the WNDR4500 for the main wired and wireless network, however I'm not entirely sure how to go about this.
I know about the hidden page
http://192.168.0.1/mode.htm
for setting the mode
But I am clueless on what to do after that, has anybody done this before or know of any decent guides the can point me too.
I do have a static IP address provided to me by my ISP.
Many thanks for any replies.
Message 1 of 11
sabretooth
Apprentice
Re: DG834N modem only and WNDR4500
All you have to do is put the 834 into bridge mode. Now it is just a modem. Set the 4500 to auto DHCP.
Message 2 of 11
jmizoguchi
Virtuoso
If you configure the DG as modem mode, next is to setup 4500 with PPP authentication and ISP are expect to use PPPoE because if your ISP will use PPPoA , 4500 will NOT work.
So if ISP uses PPPoE, then under 4500 router gui, go to basic setting and choose method type as "other" when you choose your internet requires login.
supply correct PPPoE account user and pass and should connect
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 11
bwff
Damn my UK ISP uses PPPoA, I'll just have to wait until I get Fibre Infinity 80/20 to get it completely setup, at least I can get some of the 4500 setup before the move, just can't use it. I Was hoping I could pair it with the DG834N in the meantime.
Thanks for your help.
Message 4 of 11
jmizoguchi
Virtuoso
In that case use DG as router and 4500 as access point instead
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 11
jmizoguchi
Virtuoso
http://kb.netgear.com/app/answers/detail/a_id/965
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 11
bwff
fantastic, will give it a go.
thanks
Message 7 of 11
AndyT
Novice
Out of interest (as I am likewise struggling to get a WNDR4500 + DG834N combo working), why won't the N900 work with PPPoA ... which is what my ISP uses?
AndyT
Swannanoa, North Canterbury
New Zealand
Message 8 of 11
AndyT
Novice
I've re-read this thread several times now and get the feeling that my WNDR4500 + Dg834N in modem mode + PPPoA used by my ISP won't work for some reason - so can anyone in simple lay terms:
1. Explain to me as a non-techie why it wont work
2. Advise what my options are, e.g. Do I simply need a different brand or model of modem or is there a software workaround?
AndyT
New Zealand
Message 9 of 11
sabretooth
Apprentice
Yes, because in the WNDR4500 manual it states that only PPPoE, PPTP or L2TP are the only supported ISP encapsulation.
Message 10 of 11
jmizoguchi
Virtuoso
Just about all routers in consumer level only support PPPoE (ppp over ethernet ) over PPPoA (pop over ATM)
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3650 views
  • 0 kudos
  • 4 in conversation
Announcements
