Reply
DGN2200 UK Wireless stops broadcasting!
Dabbsy
Hi there. Ok so it seem when I have my router set to 300mpbs the wireless will drop and reconnect straight away in most cases. Some other times the SSID will completely vanish so I cannot connect, which I find strange. I had the latest firmware v1.0.0.36 flashed but reverted back to the v1.0.0.20 factory firmware as I thought the newest one was the cause. It's still the same issue with both firmwares and yes broadcast SSID is on, wired connections work fine.
Message 1 of 4
jmizoguchi
Virtuoso
Re: DGN2200 UK Wireless stops broadcasting!
check channel interference issues..
or possible internal wireless going , bad power supply causing the internal wireless to behave like that
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
Dabbsy
Tryed a different power supply and just now it happened again, wireless disconnected SSID vanished then reconnected straight away? I've set the router to up to 145 mode and I'm going to monitor that for drops. Strange thing though in my statistics section WLAN shows as being connected for 12+ hours, the same as the other connections?
Message 3 of 4
jmizoguchi
Virtuoso
check for channel interference is with other surrounding
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2492 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
